Discussion topic: Sky Q Remote TV Controls for Sharp 24FA2K
This message was authored by: TimothySky
I am trying to setup the SkyQ remote (brand new) for a Sharp 24FA2K. From the 11 options offered in the setup menu none work (although 5 and 8 do cause LED to react on the TV but still no volume controls).
Sharp web pages suggest code "5459" for Sky Q but I can not see anyway to manually input a code. https://www.sharpconsumer.com/sky-remote-codes-5459/
I beleive this to be IR controlled as the TV remote doesn't work when covered.
Any other ideas? Other TV Modes using "5459"? Thanks!
Re: Sky Q Remote TV Controls for Sharp 24FA2K
Try using Vestel as the TV manufacturer on the setup menu. They often make TVs for the cheaper manufacturers, including Sharp, so it may be that one of their codes will work.
Avatar for TimothySky
Sadly the 11 Vestel options didn't yield a result
This message was authored by: dave492
select fox as the manufacturer and then use don't know the model and work through the list, mine paired on the 2nd option
