This discussion topic has been answered Discussion topic: Sky Q Remote Control Problems
Message posted on 23 May 2024 04:18 PM
Re: Sky Q Remote Control Problems
@MikeySti Have you tried switching off Bluetooth on on devices near to the Sky box? That's what sorted it for me!
Message posted on 10 Jun 2024 08:51 PM
Sorry for the late reply, its not a bluetooth issue as the voice command is transcribed word for word on screen, it just wont do the search. Have since had a replacement box and remote from sky and its exactly the same. I have it connected via ethernet does that make any difference,?
Message posted on 05 Aug 2024 02:54 PM
Unhappy sky customer I have tried everything possible to get my remote to work properly if you canno
My sky controller does not work properly I have tried everything to make it work I'm a very unhappy customer
Message posted on 29 Aug 2024 12:17 AM
Just this week the sound commands on my Q-Box Sky remote stopped working. I also have a Sky Mini and everything works perfectly including sound.
I tried another remote control with sound on my Q-Box and the 1-3 part of the process never succeeds. If I try a non-sound remote control this works perfectly. Both of my sound remotes fail to connect at the 1-3 state.
This seems to have started since the last Q-Box update which added Sky Sports+.
I have rebooted all of the boxes and restarted the network (I use LAN not WiFi) and nothing changes the problem.
Sky just offer the usual reset everything instructions and, after that, don't seem to have a clue.
This problem is definitely a problem in the software.
Message posted on 07 Sep 2024 11:04 AM
Just got the Q box, and the 4 coloured buttons on the romote control don't do anything. Also when I try to use 'on demand' or 'catch up' it says I need to up grade. At the moment I wish i'd stayed with the 10 year old HD+ box.
Message posted on 07 Sep 2024 01:50 PM
@PeterRock the 4 coloured buttons dont do too much the red button is used as the red button was on the HD box the green button is used occasionally
Sky signature comes with live TV, catchup and boxsets.in SD as standard you may be trying to download the programme in HD
The default download setting is set to HD so try changing the format to download in SD
you can change the default to SD by Pressing Home on your Sky Q remote and select Settings, then Setup.
Select Preferences, then 'On Demand default download format', and choose SD.
Message posted on 07 Sep 2024 07:31 PM
@Laing1,thanks for the advise, it is all fine now.
Message posted on 23 Mar 2025 05:41 PM
Hello.
Some of the buttons on my Sky Q Remote have stopped working, 6, 7, 8, 9, 0 plus the > button.
Bought a brand new Sky Remote but can't unpair the old remote (numbers not responding) and the new Sky Remote will
not just pair up it seems.
I can't watch any of my recorded shows because I can't move them to the right to select.
Any help please? I have tried all
of the various suggestions above.
Thanks. I'm obviously missing something.
