17
This discussion topic has been answered Discussion topic: Sky Q Red button - full screen
This message was authored by: Neil-25
I'm watching a football game on the red button but it shows the game and then on the right hand side of screen the score of the game I'm watching and the table .. how do I watch the football game full screen please ? Don't want the table on the screen too ?
This message was authored by: Rob000169 Answer
Re: Sky Q Red button - full screen
I found it via
home
sport
football
more live championship games
Same here, cannot work it out
Avatar for Neil-25
Why offer the footie and not full screen option ??? Bizarre
I found it via
home
sport
football
This message was authored by: plbaxter1
I have to say the organisation of the football on the red button is a complete mess. Just finding the game at the start was completely non intuitive and now after watching the first half on part of the screen it seems that at some point during the first half a link on the main menu comes up to watch the game.
hi @Neil-25
I am not sure if this is what is needed - I don't watch the football - but I have just tried - I noticed athat the Watch Live below the thumbnail is actually a button & you may need to use the down arrow to highlight it & then press enter to actually Watch live
Edit : I trust you don;t have an old 'Touch' remote as the newer Red button menus don;t work too well with them
That gives you the part screen.  You have to wait until someone at Sky can be bothered to put the game on the main menu and select from there.
Avatar for Neil-25
That's what I did thanks from the sports football menu 👍🏻
@plbaxter1 have you tried the solution posted by @Neil-25
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Yes as I said that works but only part way through the game.
Selecting the Watch Live 'button' (by tabbing down)  worked for me (although I still had to press the dismiss button to remove the right hand menu bar)
Avatar for Neil-25
I couldn't find a dismiss option ..
The normal back/dismiss button on the remote (3 sided rectangle wit arrow pointing left)
This message was authored by: best+of+the+best
@Rob000169 wrote:
I found it via
home
sport
football
Fair comment @Rob000169 I was watching golf so really don't want to be pressing all those buttons
If the same can be achieved by pressing the red button like @nigea99 posted pressing the dismiss button takes you to full screen then pressing the select button on the Sky Q remote allows you to select a different match.
This message was authored by: Colsal
Press left arrow worked for me
Answered - Go to Answer
