Discussion topic: Sky Q Not recording in HD
Message posted on 11 Jul 2023 01:23 PM
My Sky Q box is not recording in HD at all times. This happens on various different channels. The show is broadcast in HD but when I play the recording it's SD. Does anyone know how to fix this?
Message posted on 11 Jul 2023 03:23 PM
Re: Sky Q Not recording in HD
Hi @RossFarrel
Are you referring to recordings made specifically from the TV channels via the TV Guide or are you referring to Catch up / other downloads that you have initiated
If it is downloads then check your download preference
Main Menu -> Settings -> Setup -> Preferences
Message posted on 11 Jul 2023 10:30 PM
Thanks, no it's all programmes on series links.
Message posted on 11 Jul 2023 11:04 PM
@RossFarrel Are you sure that you are setting up the recording on the HD version of the channel?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 13 Jul 2023 04:45 PM
It's recordings on series links usually. Happens with various channels but not all.
