Discussion topic: Sky Q Multiroom
Re: Sky Q Multiroom
@Thevoid wrote:
Is it £50 per additional box?
Yep.
Re: Sky Q Multiroom
Unfortunately it is, yes (only the fee for the 1st tends to get waived)
Re: Sky Q Multiroom
Don't expect a Sky Stream puck as used in the picture though! 🤣
IMG_7542.jpegBargain… 😳
Avatar for Thevoid
Level 3 icon
This message was authored by: Thevoid
Re: Sky Q Multiroom
That's shocking! You only have the boxes on loan. Can I buy my own from eBay?
Re: Sky Q Multiroom
You can, but as I understand it they won't work as they are not linked to your account.
Re: Sky Q Multiroom
You'd be buying stolen property if you did.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Re: Sky Q Multiroom
@Thevoid
If you do you'll be handling stolen goods.
▪️I AM NOT A SKY EMPLOYEE ▪️
Avatar for Thevoid
Level 3 icon
Re: Sky Q Multiroom
Ah ok thanks for the warning, I didn't know. Would get direct from sky then.
Still disappointed it'll cost £100 to have two additional boxes.
Re: Sky Q Multiroom
@Thevoid
Non refundable.
