Discussion topic: Sky Q Multiroom
Message posted on 16 Feb 2025 02:22 PM
Re: Sky Q Multiroom
@Thevoid wrote:Is it £50 per additional box?
Yep.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
Re: Sky Q Multiroom
Unfortunately it is, yes (only the fee for the 1st tends to get waived)
Message posted on 16 Feb 2025 02:26 PM
Re: Sky Q Multiroom
Don't expect a Sky Stream puck as used in the picture though! 🤣
Bargain… 😳
Message posted on 16 Feb 2025 03:06 PM
Re: Sky Q Multiroom
That's shocking! You only have the boxes on loan. Can I buy my own from eBay?
Message posted on 16 Feb 2025 03:08 PM
Re: Sky Q Multiroom
@Thevoid wrote:That's shocking! You only have the boxes on loan. Can I buy my own from eBay?
You can, but as I understand it they won't work as they are not linked to your account.
Message posted on 16 Feb 2025 03:14 PM
Re: Sky Q Multiroom
You'd be buying stolen property if you did.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 16 Feb 2025 03:15 PM
Re: Sky Q Multiroom
Message posted on 16 Feb 2025 03:47 PM
Re: Sky Q Multiroom
Ah ok thanks for the warning, I didn't know. Would get direct from sky then.
Still disappointed it'll cost £100 to have two additional boxes.
Message posted on 16 Feb 2025 03:48 PM
Re: Sky Q Multiroom
