Discussion topic: Sky Q Multiroom
This message was authored by: Thevoid
Sky Q Multiroom
Hi, when ordering Sky Q and Multiroom, do you only get the option for one Multiroom box? How would you add more and how much are they each please?
Re: Sky Q Multiroom
@Thevoid
Multiroom is a Sky+ term. For Sky Q it's called Sky Multiscreen.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Be aware the older original 1TB (non-UHD) Sky Q box only allows one mini to be in use.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Avatar for Thevoid
Level 3 icon
Re: Sky Q Multiroom
Thanks. If the main box allows 2 mini boxes, how can you have up to 4?
Re: Sky Q Multiroom
@Thevoid
@Daniel0210 wrote:
You can have a maximum of 4 mini boxes in total loaned to you by Sky. You can watch Sky content on any two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+.
Avatar for Thevoid
Level 3 icon
Re: Sky Q Multiroom
So can I go for the 1TB box and still have 3 minis, but only watch TV on the main box and one mini box at the same time?
Re: Sky Q Multiroom
@Thevoid
Yes
1TB boxes are the standard issue Sky Q boxes now. I believe 2TB boxes are in short supply so are probably used to replace faulty 2TB boxes.
Re: Sky Q Multiroom
Depends on the hardware version of the 1Tb box.
Newer ones support 2 concurrent minis.
Avatar for Thevoid
Level 3 icon
Re: Sky Q Multiroom
Thanks. How do you order more mini boxes and are they free with your subscription to multi screen?
Re: Sky Q Multiroom
£50 each admin fee for delivery I believe. Not sure how you order them. Had mine since the dawn of history 🤣
Re: Sky Q Multiroom
No
Main and two mini boxes (and 2 tablets on top of that) unless you have the really old 1TB main box referenced above.
Re: Sky Q Multiroom
Hi @Thevoid   I have add Mini boxes on My Sky https://www.sky.com/mysky/tv There is no extra subscription, just the one off admin fee of £50.
Avatar for Thevoid
Level 3 icon
Re: Sky Q Multiroom
Is that £50 per box?
It's a bit cheeky asking for another £50 to use a servicing you're already subscribing to (multiscreen)
Re: Sky Q Multiroom
Hi @Thevoid
Basically it's an activation charge.  Used to be an additional charge for viewing on another TV.
Re: Sky Q Multiroom
Well DPD don't deliver it out of the goodness of their hearts 😁
Avatar for Thevoid
Level 3 icon
Re: Sky Q Multiroom
Is it £50 per additional box?
