Discussion topic: Sky Q Mini boxes dissconnecting constantly
This message was authored by: Jm171264
I have 2 mini boxes and they constantly keep disconnecting from the Main Sky Q Box. Despite bieng there they just constanly keep disconnecting and the only way to get them back is either reactivate or reset the network.
Anyone else had a similar issue - unsure if it is the main box causing the issue or if it is the mini's?
This message was authored by: Addie15
Re: Sky Q Mini boxes dissconnecting constantly
Hi there, @Jm171264. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Hi @Jm171264 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with any Mini boxes?
This message was authored by: Lisa-P1987
We are still looking to help you @Jm171264 . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Yep had this constantly, hence I now use powerline adapters.
This message was authored by: SN2
Every single day I need to reboot and reconnect. Super frustrating. Wondering if I need a new mini box, reset from the main sky q box or switch providers.
@SN2 is there any specific time of the day your box does this or is it anytime of the day
This message was authored by: Trm16
I am having exactly the same problem ... been going on for days now. I've rebooted the WiFi multiple times ... rebooted the main box multiple times and rebooted the two sky q boxes multiple times
So frustrating that they connect temporarily and then disconnect ... had been fine for years and now doing this!!!
Have escalated. Watch out for a blue chat bubble.
Hi there! Thank you for escalating this. We have sent an invite to Trm16.
Where is the invite?
This message was authored by: safe-power
I've been having the same issues for weeks, but in the last few days the problem has just got worse. I spent over an hour yesterday rebooting everything over and over again, managed to connect at one time but without sound.
It finaly conected correctly then dropped out 15 mins later and now will not connect at all !! Engineer is now booked at a cost of £15...
@Trm16
Look out for a blue/red speech bubble at the bottom of your forum page. Once that appears you have 48 hours to click on it and join the private chat or it will close automatically. If you fail to respond to each chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky are not instant so you’ll need to regularly check the chat thread.
This link explains the Community Messaging process.
@safe-power
Why is there a cost? Sky Q equipment is loaned to you and maintained by Sky.
Update-We are closing this invite now due to no response. If you still need help, please let us know so we can re-escalate this for you. Thanks.
