Discussion topic: Sky Q. Mini box saying no subscription
This message was authored by: Matty38
Sky Q mini box saying I have not got subscription
Re: Sky Q. Mini box saying no subscription
@Matty38 Have you unplugged it and plugged it back in again? I assume you do have an active Multi-room subscription in place?
Avatar for Matty38
Level 0 icon
Yes  to both
@Matty38 You may need to ring Sky then.
@Matty38  Is this affecting all channels or just some?
 certain channels which ones are affected
Hi @Matty38
Try a Reset Settings in the main Q box hidden menu.
When the main Q box is back up and running after the reset then reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini  box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
