Discussion topic: Sky Q Mini Wifi Extender With Sky Max Hub
This message was authored by ArvidS1 This message was authored by: ArvidS1
We recently subscribed to Sky  Broadband coming over from BT. We have been Sky Q and Sky Mobile customers for a while and wanted to bring Broadband over to Sky as well. One of the advantages I was hoping for is using our tw Sky Q Mini Boxes as wifi extenders and do away with the many BT Discs we have to cover the house and Annexe through an external wall.
After troubleshooting I have just been told by Sky that the Sky Max Hub does not enable Sky Q Mini Boxes as wifi extenders any longer? Is this correct?
Will a newer generation of Sky Q Mini Boxes become wifi extenders with the Sky Max Hub?
Re: Sky Q Mini Wifi Extender With Sky Max Hub
Hi @ArvidS1
Apparently the Sky Max acts like a 3rd party hub and so Minis will not be Hot Spots.
Secondly there is no newer Generation mini on the cards and Sky are concentrating new development on Stream.
ArvidS1
Thank you @oldfella
I read somewhere the Sky Q Mini can be set up as a third party device, would that make a difference?
@ArvidS1 wrote:
Thank you @oldfella
Hi  @ArvidS1
If you mean Hot Spots with 3rd party broadband then yes if the option is in the Main Q box menu.
see link.
https://www.sky.com/help/articles/wifi-hotspots
