Discussion topic: Sky Q Mini Setup
This message was authored by: Fraser11
Sky Q Mini Setup
I've just received a new sky Q mini. Already have SkyQ TV and broadband. Have plugged in and started up sky mini box. And keep getting the message."No IP address obtained"Have reset the sky Q router as instructed and tried again several times and keep getting the same message. All other devices connect to Wi-Fi as they should. Any help?
Re: Sky Q Mini Setup
Hi @Fraser11
Assume this is your second mini and you already have Sky Q Monthly Multiscreen subscription?
Reboot the mini as above.
This message was authored by: alexcarey
Ensure your Sky Q mini box is within range of the Sky Q router and try a wired connection using an Ethernet cable. If the issue persists, contact Sky support for further assistance.
