Discussion topic: Sky box struggling to stream or populate menus
Message posted on 03 Aug 2024 09:44 PM
All streaming apps ( Netflix etc.) are slow to stop. The main Sky menu screens very slow to load.  We are on very stable full in-premises fibre with average WiFi speeds of +200mbs.
We've tried rebooting skybox, monitoring WiFi speeds etc. We've had the same Skybox for 8 years with no issues. Suddenly it has started acting up. In network settings we can see the connection turn on and off, yet nothing has changed on the network. Any ideas?
Message posted on 03 Aug 2024 09:52 PM
							Re: Sky box struggling to stream or populate menus
Hi @Malkie000
Message posted on 05 Aug 2024 08:21 AM
Tried that to the letter. Everything seemed ok for about an hour or so, then it started slowing down again and lasting much longer each time.
