Discussion topic: Sky Q Mini Boxes Loosing Connection
SwedeBaggie
This message was authored by SwedeBaggie This message was authored by: SwedeBaggie
Re: Sky Q Mini Boxes Loosing Connection
Perfect will do that.
Just to make sure will do the following steps:
- Unplug the Mini via ethernet
- They have the Virgin Hub so I should plug the Q box into this
. Reset network on mini
Is that the steps?
Is that the steps?
Hi @SwedeBaggie
If you get the mini and the main Box on Ethernet follow the procedure to first carry out the network reset on the main Q box with the Ethernet connected
No WPS and select wired to non Sky router.  When it connects switch of WiFi on main box.
Then Network reset on mini no WPS just wait.  Again when it connects immediately switch off the WiFi in the mini.
I know you switched it off before but a Network reset switches it on again.
Fingers crossed you should have perfect connection on main box and that mini.
SwedeBaggie
Thanks as always, doing these steps now
SwedeBaggie
Mega annoyingly after doing these steps  I still get exactly the same behavior. Have done this with both mini boxes. The internet speed is decent (300 Mb) and on mesh and get this speed pretty much over the whole house.
Is there anything else I can try ?
Just explain exactly how all the boxes are connected @SwedeBaggie
SwedeBaggie
Of course - Main box into Virgin Hub with 2M Ethernet , mini box into Virgin Hub with 20M Ethernet (although distance is around 7M) .
Other mini box not connected to power.
i also turned off wifi completely on the Virgin Hb and powered off the mesh Network just to be certain .
Hi @SwedeBaggie
Have you checked in both boxes that the WiFi is still all off?
Also What mesh are you using and are any nodes near each box?
SwedeBaggie
Using eero , boxes are close by to main box but not mini box.
WiFi is definitely off on the main and mini box
Hi @SwedeBaggie
If you had a node near to each box you could have tried Ethernet to nodes instead of router. They all must be Ethernet connected to same method. Ie all to nodes or all to router.
Edit
Doesn't your 20M Ethetnet allow you to connect you mini to a node?
Well I'm out of ideas.   Ethernet connection to all Q boxes should be bulletproof.
Have you tried rebooting the Router before making the Connections?
Clutching at straws really I suppose.
All I can suggest is an Engineer visit to see if they can help.  Some however don't like Ethernet.
SwedeBaggie
Hi ,
I can easily move nodes around - will try that now just incase it makes a difference.
Will start by rebooting everything and seeing how we get on following your instructions
so unbelievably grateful that you took so much of your time
@SwedeBaggie wrote:
Hi
Hi @SwedeBaggie
Only sorry you are not up and running.
Assume your Ethernet cables are all fully wired?
Have you checked them in any way?
More straw clutching 🥺
Edit
Main box, you need wired to non Sky router in Network setup (although it's one of your nodes.  Q box will only see an Ethernet connection.
SwedeBaggie
Super strange now but maybe it's common .
when connecting to nodes - the main box works perfectly .
the mini box now says No Satellite signal - nothing seems to work but it's a different message . Not sure if this is positive / negative or totally indifferent
everything is wired, have connected to laptop and wired connection works as expected
Does the mini appear to connect OK in the Network reset @SwedeBaggie ?
SwedeBaggie
It does yes - both have ticks next to them .
Feel defeat is close - do I call to try to schedule an engineer ?
hi @SwedeBaggie
When they have both been connected there's two things you can try.
Then reboot the mini as above.
Failing that it might be worth trying a Reset Settings in the main Q box hidden menu.
