6
This discussion topic has been answered Discussion topic: Sky Q Mini Box Not Connected to Router
This message was authored by: Pabs101
I am getting an error code MR102 with my sky Q mini box. There is a problem joining your network.
My main sky Q box is fine, broadband/WiFi is fine and all other devices connected to the WiFi work ok. It's only the sky Q mini box which no longer works.
ive tried to reactivate the box with the main sky Q box, rebooted my router, pressed that little button on the router but not getting any luck here. Started last night and no change this morning after trying all of the above again. Any advice please?
Avatar for Pabs101
This message was authored by: Pabs101 Answer
Re: Sky Q Mini Box Not Connected to Router
Turns out the WiFi chip was knackered and the whole box needed replaced. Didn't have to wait too long on a sky engineer to come out and now all good! Thanks @oldfella  and @Quoman7  for your suggestions again
Hi @Pabs101 in the following order:- Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with the mini box?
Avatar for Pabs101
Thanks for that suggestion @Quoman7 but it hasn't worked
Hi @Pabs101
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.  However if you are on Sky broadband with the Sky Max router you have to connect to the main Q box as above.
Avatar for Pabs101
Thanks for that @oldfella and when I called up Sky we started doing that and reconnecting the remote but for some reason when it came to reconnecting to the Sky WiFi the option couldn't be selected! Same with the option to select another provider! I've now got an engineer on there way to the house tomorrow morning
Avatar for Pabs101
This message was authored by: BrianDuke
My viewing card is inserted correctly, but still get the message 'No viewing card'
