Discussion topic: Should I set up sky tv box?
This message was authored by: charb
Im switching from virgin tv/broadband to sky. The broadband is being set up in a couple of weeks but I received the tv box today. Should I wait for broadband switch or can I connect sky tv now?
Re: Should I set up sky tv box?
You don't have to wait.
Also, you mention switch.  Remember that TV services are not included in OpenTouch Switch - so if you haven't given Virgin notice about your TV then it will remain active until you do.
Hi @charb
If you are getting Sky Q you need a Satellite dish and the correct Wideband LNB.
If it is Sky stream you are  getting then you need to post in the Sky stream forum.  You post can be moved to the  correct forum if you confirm you are not getting Sky Q TV.
Normally with Q all TV equipment is supplied by the Engineer at Installation and only the broadband router is sent out beforehand.
