Discussion topic: Sky Q Mini Box - Keeps showing 'Technical Fault' on screen
Message posted on 28 Mar 2023 08:32 PM
We have a Sky Q Mini Box in our bedroom, about 4 metres from the main Sky Q Box and 3 metres from the Broadband router. The main Sky Q Box always works without fail, but the Sky Q Mini in our bedroom constantly says 'Technical Fault' and we cannot view any channels. Every night we are going through the prompting of resetting this and that, but each time - EVERYTHING is connected and working, even tick boxes on the cheks on the Sky menu . . . .Anyone have any idea how we can actually start watching TV in our room again? Thank you much appreciated!
Message posted on 28 Mar 2023 08:33 PM
Re: Sky Q Mini Box - Keeps showing 'Technical Fault' on screen
Who is your broadband supplier @Peely888
Message posted on 13 May 2023 01:39 PM
Hi, having the same problem as you, however our main box isn't working either.
Have you sorted it or had and assistance?
Cheerd.
Message posted on 30 Sep 2023 03:07 PM
I have the same issue. Have tried the standard resetting. Anyone managed to fix it?
