Discussion topic: Sky Q Mini Box Error MR106
This message was authored by: cuke
Re: Sky Q Mini Box Error MR106
And the other things you can check is that all the minibox's and the main box are running the same firmware version. Also delete fully any unwanted and deleted recordings https://www.sky.com/help/articles/recording-on-sky-q#:~:text=Managing%20your%20recordings,Recordings....
Avatar for Belinda17
This message was authored by: Belinda17
@cuke I finally got mine working by plugging it in near to the Sky Q box and the Broadband Roater, I will have a look at my settings
@Belinda17 wrote:
My Sky Q Mini Box isn't working, I get the Error MR106 along with Your Sky Q Mini Box has not been able to connect to the activation server.
I have unpluged the router and turned off both boxes but still getting the error code
Check also that all the boxes are on the same standby settings...
This message was authored by: RichardMUK
I found that by rebooting my WiFi router (Vodafone) then restarting my Sky Q box and then restarting my Sky Mini Box solved the problem.
This message was authored by: Boris+Blank
@RichardMUK
That worked for me, thanks!
