Discussion topic: Sky Q Mini Box Error MR106
This message was authored by: Belinda17
My Sky Q Mini Box isn't working, I get the Error MR106 along with Your Sky Q Mini Box has not been able to connect to the activation server.
I have unpluged the router and turned off both boxes but still getting the error code
Re: Sky Q Mini Box Error MR106
Set the mini up again from scratch
Hi @Belinda17
Try a Network Reset on the mini.
This message was authored by: Darren26
Avatar for Belinda17
Am still getting it the above answers haven't helped
Who is your Broadband supplier @Belinda17
@oldfella Its Virgin Media
Hi @Belinda17
what happens when you reboot the mini?
@Belinda17 when you go into home>settings>status does watch on Sky Q mini have a tick against it if not scroll across and down to that the try reactivate
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
I get the same message and it won't let you into the box, I have other mini box's and they work fine
@Laing1 I can not get into the box as soon as I turn it on I get the message and can't get pass that
Hi @Belinda17
Maybe worth swapping over the mini with one that is working just to see it will connect at a different location.   Choose the mini nearest to the main Q box if possible
@oldfella I will give that ago tomorrow and see if it works or not.
Am trying to figure out how you add a photo so you can see.
@oldfella wrote:
Hi @Belinda17
@oldfella wrote:
Hi @Belinda17
Hi @Belinda17
You click the camera icon above the post box to add a photo.
Edit
If you wasn't aware MR 106 is a connection error
This message was authored by: ed68
I've been having this issue for the past couple of days. I've just spoken to Sky and they advise to change the setting on the main box and mini box to active from eco.  Apparently, in eco mode the box goes to sleep from 4am until 6am. However, if the box doesn't wake up properly the MR106 Error may occur.
Will have to wait and see if this solves the issue.
