Discussion topic: Sky Q Main Box and Mini box issues
This message was authored by: carterr3
My Sky Q box keeps disconnecting from the service, I sometimes get a 'no satellite signal' message and sometimes a 'cannot connect to WiFi' message, my 2 x mini boxes are also regularly presenting a 'cannot connect to WiFi' or 'not connected to main box' message. Even though this is resolved with a box reset it keeps occuring and is happening more frequently in the last month or so.
Re: Sky Q Main Box and Mini box issues
Hi @carterr3
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Regarding No Satellite signal
Work through the following link and if you cannot solve your issue it will lead to booking a Engineer.
Alternately, if you are on a Communal Dish you will need to contact your Landlord or Management company.
This message was authored by: Steve+the+Gooner
I've been getting the same all over the Christmas period, having to reset everything most days. Got the fastest full fibre package available offered by Sky but the service is still pants!
Paying best part of £150 a month for this **bleep**e!
