Discussion topic: Sky Q Internet Connectivity
This message was authored by: JaimeT
Have had Sky for years.  Have a Sky Q box and it now keeps disconnecting from the internet 5-6 times a day regularly..   anyone know why?
Re: Sky Q Internet Connectivity
Hi @JaimeT
Have you tried completly resetting the connection?
