5
This discussion topic has been answered Discussion topic: Hi. I am not able to get the home page on my Sky Q. I have checke my handset and replaced the batter
This message was authored by: Rubi1
Earlier this evening when I turned on the tv I was told I was not connected to the internet so went to settings and sorted that out. I then was able to watch about 60 minutes of a film and then it just went blank. Just leaving the HDMl1 in the top left hand corner. I have changed the batteries on the hand set but nothing brings the home page up.
Re: Hi. I am not able to get the home page on my Sky Q. I have checke my handset and replaced the ba
@Rubi1 wrote:
green
Hi @Rubi1
Have you cycled through the HDMI inputs on the television?
Also have you tried rebooting the television set by disconnecting the power lead for 30secs and then reconnecting.
Also try rebooting your Q box.
Is the Q box on with Green led @Rubi1
If not
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for Rubi1
Nothing has changed
@Rubi1 wrote:
Nothing has changed
What colour is the led on the front right of the Q box @Rubi1 ????
Avatar for Rubi1
green
@Rubi1 wrote:
green
Hi @Rubi1
