Discussion topic: Sky Q Box won’t turn on after being put on standby. Sometimes is un responsive when watching tv.
Message posted on 27 Aug 2023 10:45 AM
only way to correct problem is to unplug at mains, wait a couple of minutes and switch back on.
Message posted on 27 Aug 2023 10:49 AM
Re: Sky Q Box won’t turn on after being put on standby. Sometimes is un responsive when watching tv.
Hi @Lordspud
Message posted on 01 Sep 2023 07:56 AM
Thanks. Have tried that. We'll see if that helps.
Message posted on 20 Dec 2023 01:50 PM
After getting a message saying that I have no internet connection even though my internet is working perfectly around the house i done a reset on the sky Q box and after I done it the sky box won't turn on it's completely dead.
