31 Dec 2024 01:30 PM
Main Sky Q Box has no Network Connection, it's unable to connect the Sky Router. Wifi is working with no problems but the Sky Q Box cannot connect. I have followed the instructions below (provided by @oldfella) and its still failing to connect to the router....any ideas anyone??
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure the main box WPS light is flashing and then press the WPS button on the Sky router
31 Dec 2024 01:38 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Suz74
If your are using the Sky Max router try connecting it by SSID and Password instead of WPS
