Discussion topic: Sky Q Box not responding, have to reboot
Message posted on 09 May 2024 12:57 PM
My Sky Q box is failing to power on/respond 2 - 3 times a day, this happens at various times during the day.
A reboot solves the issue but only temporarily, any comments/suggestions?
Message posted on 09 May 2024 01:28 PM
Re: Sky Q Box not responding, have to reboot
Message posted on 11 May 2024 04:42 PM
Tried the above, my box seemed faster generally but still failed to power on today (even though box was set to stay on).
I have ordered a box swap.
