Discussion topic: Loss of signal
Message posted on 26 Feb 2024 01:00 PM
Loss of signal
One of the white wires has been pulled from the back of the main sky q box, I have tried to reattach but the wire won't go through, need an engineer.
Also need replacement mini boxes as the equipment is old and damaged too.
Message posted on 26 Feb 2024 01:28 PM - last edited: 26 Feb 2024 01:28 PM
Re: Loss of signal
you can't just push the wire in. It has to be reattached to the plug properly to make sure the contact is clean for the centre wire and the outer sheath.
you have to unscrew the f-plug from the box to do this. It's not engineer territory to be honest. Simpler than wiring a plug.
Message posted on 26 Feb 2024 02:19 PM
Re: Loss of signal
Sky will only replace Sky Q box / mini boxes if they are faulty and not working. They won't replace them once they are of a certain age. If you've damaged them you're likely to be charged for any replacement as and when the damaged one is returned.
Message posted on 28 Feb 2024 10:05 PM
Re: Loss of signal
I ended up getting an engineer after you gave less than accurate advice, all problems now fixed but this service was no use, and tbh quite patronising.
The engineer required tools to reattach the wire to the box so maybe not quite like wiring a plug.
Message posted on 11 May 2024 04:38 PM
Re: Loss of signal
@Claremcnic wrote:I ended up getting an engineer after you gave less than accurate advice, all problems now fixed but this service was no use, and tbh quite patronising.
Interesting. What tool did he use? The end caps can be quite tricky to loosen but are usually hand-tight. Maybe it needed cutting, which has to be done carefully and there are specialist cutting tools for that, if the cable was damaged badly enough when it got pulled out.
Message posted on 11 May 2024 04:56 PM
Re: Loss of signal
@Chodley wrote:
@Claremcnic wrote:
I ended up getting an engineer after you gave less than accurate advice, all problems now fixed but this service was no use, and tbh quite patronising@.
@Chodley wondering if he used crimped connecters as they used crimped connecters on mine when they set it up 8 years ago and that is what @Claremcnic saw the engineer using
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 11 May 2024 04:57 PM - last edited: 11 May 2024 04:58 PM
Re: Loss of signal
@Laing1 wrote:
@Chodley wrote:
@Claremcnic wrote:I ended up getting an engineer after you gave less than accurate advice, all problems now fixed but this service was no use, and tbh quite patronising@.
Ah yeah possibly. Don't like those, but probably quicker & easier for installers.
