Discussion topic: Sky Q Box needs hard resetting daily
Message posted on 30 Jan 2024 09:29 AM
I need to do a full reset of my Sky Q Box every day as it keeps losing the picture completely, only for about a second, but that quickly becomes very annoying, anyone out there got a fix..?
Message posted on 30 Jan 2024 10:06 AM
Re: Sky Q Box needs hard resetting daily
First thing to check is your HDMI lead. Make sure it is correctly seated both ends. Try another if you have one.
What "full reset " are you doing?
Message posted on 30 Jan 2024 10:58 AM
Turning the box off at the plug for at least 30 seconds to make it do a full reset of the sky box
Message posted on 30 Jan 2024 11:04 AM
Yeah.... that's just a reboot.
If you have checked the HDMI lead then try a Reset Settings in the Q box hidden menu.
Message posted on 30 Jan 2024 11:35 AM
Just tried, and reset the sky controller so it controls the telly, heres hoping
Message posted on 30 Jan 2024 12:58 PM
I have exactly the same problem. My TV says "No signal" despite the Sky box being on. The only way to fix this each time is to unplug the Sky box, ie a hard reset.
Message posted on 30 Jan 2024 01:05 PM
As mentioned in my post just now I have this problem too. I could try the reset that old fella suggests but I'm not sure what he means by LNB. If I try the reset what could happen to my Sky box (and what does LNB mean)? Thank you.
Message posted on 12 Apr 2024 10:27 AM
Re: Sky router Box needs hard resetting daily
Since signing up to broadband with sky. I have to power off an back on my sky router box everyday. It looses connection usually between 9 am and 10am everyday. Once reset it works fine. It's just a daily occurrence which is annoying. I could be the result of the system being backed up daily by sky or it could be a glitch in the system is my assumption.
anyone else having to do this daily?
