Discussion topic: Sky Q Box Won't Switch On
Message posted on 26 May 2024 03:15 PM
Sky Q box won't switch on, have turn it off at the mains, it goes through all the relevent pages as normal but after the 'when the screen goes blank press the home button' but nothing happens, have done all the usual help suggestions that from the help pages but still nothing is happening, just stays on the orange light.
Any suggestions?
Message posted on 26 May 2024 03:24 PM
Re: Sky Q Box Won't Switch On
Any suggestions?
After it has gone blank, press the On button and ensure the LED goes green
Then press the following keys in Sequence
Home 1 0 8 0 Home
Message posted on 26 May 2024 03:45 PM
Any suggestions?
Hi @1975clan1
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 26 May 2024 07:59 PM
Thanks for ideas, tried everything, nothing worked, gave up and phoned sky, all sorted now
Message posted on 26 May 2024 09:01 PM
Could you please share what the solution was as it may help others who search and end up here in future.
Message posted on 28 Dec 2024 10:46 AM
It's happened to me a few times too. Very annoying!!
Message posted on 30 Dec 2024 12:54 AM
I've had what looks like the same issue for the last year or so. It started out that I had to unplug the box and it would start up as normal afterwards, this happened a couple of times a week. This has progressed to the point where it might happen several times a day .I follow the steps stated on Sky's website to reset the box. It can take many attempts and over an hour to get the box to work again ,often a red light will remain on in the Q button
I've ordered a new box which should come tomorrow
Message posted on 30 Dec 2024 08:13 AM
@godwinson1066 wrote:I've had what looks like the same issue for the last year or so. It started out that I had to unplug the box and it would start up as normal afterwards, this happened a couple of times a week. This has progressed to the point where it might happen several times a day .I follow the steps stated on Sky's website to reset the box. It can take many attempts and over an hour to get the box to work again ,often a red light will remain on in the Q button
Don't forget your viewing card 😉
and swap the power connector too just in case it's the different type.
Message posted on 30 Dec 2024 08:55 AM
I read somewhere on the Sky website that, if you've got Sky Go on your phone, you can switch the box on from the app. It worked for me. The app has a little mini controller that looks similar to the real handset. I pressed the Home button on that(looks like a house) and the tv and box did turn on.
Message posted on 30 Dec 2024 09:42 AM
Yes.
Using Sky Go on an Apple phone or iPad does have a Sky Q remote control function.
It is not available on the Android or PC version of Sky Go.
We have not heard anything on when or if it will come to those devices anytime.
Message posted on 30 Dec 2024 10:41 AM
Luckily I have an iPhone! Curious that it's not available on Android phones.
Message posted on 06 Jan 2025 08:48 AM
And then you presumably lose all the programmes you've recorded?!
Message posted on 07 Jan 2025 09:14 AM
@Pierre17 wrote:And then you presumably lose all the programmes you've recorded?!
I assume that was a reply to the "ordered a new hox which arrives tomorrow" post?
Well yeah - but guess what, you don't own perpetual rights to those recordings anyway and hard drives fail. As do VHS tapes and DVDs and SD cards. And no one is storing movies on punched cards.
Message posted on 07 Jan 2025 05:33 PM
I realise that but I've got a BIG backlog of recordings to watch so I'd be pretty unhappy to lose them all. I might even cry or have a tantrum.
