Discussion topic: Sky Q box keeps going to black screen, no warning messages
Message posted on 07 Jan 2025 04:09 PM
I have a fault with my Sky Q box connected to my TV. Every now and then the screen on the TV goes black, there is no message to say the connect lost, faulty, or anything else. Switching the box on/off with the remote returns to the Home Page and from there we can navigate to where we were watching.
The TV is new (same fault was on the old TV). The HDMI cable is new. All connections appear to be sound and the box has been disconnected from the power to reset a number of times.
Richard235
Message posted on 07 Jan 2025 04:34 PM
Re: Sky Q box keeps going to black screen, no warning messages
@Richard235 wrote:I have a fault with my Sky Q box connected to my TV. Every now and then the screen on the TV goes black, there is no message to say the connect lost, faulty, or anything else. Switching the box on/off with the remote returns to the Home Page and from there we can navigate to where we were watching.
Richard235
Hi @Richard235
Message posted on 07 Jan 2025 04:56 PM - last edited: 07 Jan 2025 04:59 PM
I've been getting this for over a year now. In my case it mostly happens when exiting playback of a recording. It doesn't happen often (three or four times a year perhaps). I usually find that putting the box in standby and leaving it alone for a minute or two will cure. Occasionally though it just doesn't want to know so if it's not recording anything I power cycle it. If it's recording then I leave it alone as the problem doesn't impact recordings.
I've also had the box fail to output a video signal when coming out of standby. The box is obviously alive as it successfully powers on the TV but then after a dozen seconds the TV will complain that it can't see a signal. It's probably the same fault as the fix is the same.
Unfortunately I suspect there's nothing to be done other than live with it and hope it doesn't get any worse.
Message posted on 07 Jan 2025 05:20 PM
Richard235
@Richard235 what make of TV is it ? LG?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
