Discussion topic: Sky Q Box Glitching
This message was authored by: RexT87
Sky Q Box Glitching
When I try to use Netflix or Amazon Prime, more often than not it will freeze and stay stuck until I remove the power. It's now started to do it on regular channels too. I have updated the sky q box with the latest software update, not sure what else to do.
Re: Sky Q Box Glitching
Hi @RexT87
If the box was already on the latest software then a manual update does nothing; other than an extended reboot.
