4
This discussion topic has been answered Discussion topic: Sky Q Box Ethernet Connection (Not Mini)
This message was authored by: NickF3
I have a full fibre broadband connection with Zen Internet.  I've connected the router (Fritzbox) to the Sky Q Box with an ethernet cable, turned off the WiFi on the SkyQ Box and gone through the wired connection setup menu, but the box can't find and IP address. I've power cycled both the router and the box but that makes no difference.
I've gone back to a WiFi connection until I can solve the issue.
Any ideas?
Avatar for NickF3
This message was authored by: NickF3 Answer
Re: Sky Q Box Ethernet Connection (Not Mini)
New Ethernet cable fixed the problem straight away.
Top tip: Old cables with phone socket type connectors ARE NOT Ethernet cables.
It took a few attempts for me.
tried setting a fixed address?
do other devices get an address ok using the same cable?
Avatar for NickF3
I'll check the cable out on a laptop - hopefully it's that simple!
Avatar for NickF3
😆 no, indeed not
Answered - Go to Answer
