8
This discussion topic has been answered Discussion topic: Sky Q Apps not working
This message was authored by: 21sam
I can not load any of the apps on the app menu. This is a new problem.
Have rebooted the box.
Have gone to settings and tried a refresh here with 001 enter.
Still have the problem.
Who can I contact to sort this out?
San
Re: Sky Q Apps not working
@21sam wrote:
7pm this evening
Yes OK but you didn't fully answer my Question @21sam
Be aware that Refresh Apps can take 24 Hrs to complete.  Depending when you also did the Reset settings in the hidden menu you may have interrupted the Apps refreshing.
San
Hi @21sam
Assume the refresh you did was for the Apps.
You could also try a Reset settings In the same hidden menu.
Avatar for 21sam
Yes done all of that and the APPS still won't load. None of them
Avatar for 21sam
Sky works fine apart from using the APPS
What base subscription do you have?  Signature or essentials?
Avatar for 21sam
Pass, got everything
This has only happened today and yesterday. Been with sky for years with no problems with apps.
Exactly when did you Refresh the Apps and Reset settings and in what order @21sam ?
Avatar for 21sam
7pm this evening
@21sam wrote:
7pm this evening
