Discussion topic: Sky Q 2TB red light
Message posted on 08 Jul 2023 11:42 AM
Sky Q 2TB red light
Message posted on 08 Jul 2023 11:46 AM
Re: Sky Q 2TB red light
@killer2500 wrote:
Hi, Gone through all the Sky recommended "Fix an issue" box still won't turn on. Replaced batteries in remote and tried a new Sky remote. All HDMI leads etc. are in place. Box is a year old as last one (1TB) did the same. New box (?) Thank you.
Hi @killer2500
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 08 Jul 2023 11:47 AM
Have you tried the troubleshooting here
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Message posted on 08 Jul 2023 08:28 PM
Thank you, all sorted.
