Discussion topic: i am trying to connect my sky mini q box, but i keep pressing the middle buttont and nothing
This message was authored by: chaz2405
For some reason I have to log my sky q mini box back to the WiFi
it says step 1 of 4
it says to hold down the middle button the little dot on the remote keep doing that and nothing
Re: i am trying to connect my sky mini q box, but i keep pressing the middle buttont and nothing
it says step 1 of 4
Hi @chaz2405
For step 1 you just need to press the Central (Select) button once.   This should start the mini WPS light flashing
You should then see Step 2  where you are asked to press the WPS button on the main Q box (or Q booster if you are using one).
