Discussion topic: Sky Q 2TB box has been replaced but still freezes
This message was authored by: Mm135
Sky Q 2TB box has been replaced but after a couple of days it has started with the same problem. Freezing. Staying stuck in standby.   Now dropping out of Netflix continuously.
don5 understand the problem
Re: Sky Q 2TB box has been replaced but still freezes
Hi @Mm135 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?.
