Discussion topic: Sky Q 2TB box behaving erratically
This message was authored by: Dubzzy
Noticed the box doing wierd things and just being slow. Symptoms are;
Taking time to switch between channels. Sometimes upto 40 seconds
Pausing or rewinding a program the screen goes blank or the screen freezes
Doesnt record all programs set in the schedular
Taking a program off record or series link doesn't take the R or green 2 way arrows for series link off
Some thumbnails in the home screen dont appear, this is the same under "recent rocordings"
Ive done the standard support for dummies.. turn it off and on again (unplugging from mains and turning back on after a couple of mins). Anyone able to offer any pointers?
Re: Sky Q 2TB box behaving erratically
Hi @Dubzzy
Avatar for Dubzzy
I've done the first option reset as described above and it doesn't seem to make any difference.
In the last few days I've had my broadband service and router changed. Could this be affecting it? Does the Sky Q box need a regular and consistent broadband connection to run smoothly? what features would need broadband connection. I know things like catch up, apps (Iplayer/Youtube) and streaming would need broadband connection. My Sky Q box is connected to the router by Ethernet cable, and even though it is anew broadband service and router, it is being picked up by all my devices (including this laptop I using to post here.
Avatar for Dubzzy
Another issue I have discovered is that my recordings arent showing, I cant see them. I cant see them on the home screen under "your recordings" and I can't see them in the recordings menu/tab under "recent recordings". Just see the message please wait and a wheel going around forever.
Rather than me go throough self help guides on the Sky website, which i have briefly done (and so tedious) aswell as searching for a Sky TV helpdesk number, is anyone able to provide me with a Sky Q support phone number?
thanks in advance
