This discussion topic has been answered Discussion topic: Sky One / SNL UK / No HD
Message posted on 10 Apr 2026 01:28 PM
I have Sky One as part of Sky Signature package. I can watch all programmes with no issue except for SNL UK. Trying to record results in FAILED and trying to watch on catch-up tells me I have to upgrade my subscription.
Is this because I don't have the HD version of the channel?
Message posted on 10 Apr 2026 01:29 PM
As the default download quality is set to HD (high Definition) not SD then when you try to download and watch you are prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Message posted on 10 Apr 2026 01:54 PM
Re: Sky One / SNL UK / No HD
Thank you so much, I feel ever so silly but I would that solution would not have crossed my mind so I am ever so grateful.
Message posted on 10 Apr 2026 03:50 PM
Glad this sorted it for you.
Absolutely no need to feel silly, it is not an obvious setting that possibly most people don't know it exists
