12
This discussion topic has been answered Discussion topic: Sky News 501 Suddenly Pin Protected
This message was authored by: Miikka
Hi guys
Suddenly, every time I select Sky News Ch 501 I am asked for my Pin. Never happened before! Any ideas how I remove Pin protection from this channel please? Very irritating!
This message was authored by: Chloe-W22 Answer
Re: Sky News 501 Suddenly Pin Protected
Posted by a Sky employee
Hi all,
Just wanted to pop an update that I spoke to our technical teams who confirmed "Netanyahu" is rated 12 so it would've prompted the PIN protection during the day. If you have anymore examples I'd be happy to get them checked 🙂
Chloe-W22
Sky Community Manager
Have a story you want to share with us? Send your Thanks to Sky here
@Miikka wrote:
Hi guys
Hi @Miikka
Just checked here and yes it currently needs Pin requirement
Maybe Sky have decided the current program to be Adult rated
This message was authored by: nannyflav
Mine too what a pain
@Miikka
Just turned over to Sky News at 1701 and no pin required so I think @oldfella was spot on.
Avatar for Miikka
Level 2 icon
Thanks for the replies guys. But weird for a general news chanel!
Mines ok now back to normal
The program in question was related to current events in the Middle East and was rated 12 hence the pin requirement
Avatar for Miikka
Level 2 icon
The Pin Protection has been switching on and off all day for me. Sometimes it requires a Pin, sometimes it doesn't. Maybe Sky are fiddling with something? Hopefully it will settle down eventually. Crazy to have Pin protection on a news channel!
Avatar for Miikka
Level 2 icon
FYI It was/is the program "Netanyahu" which was/is Pin protected. It's on again now and is Pin protected!
Hi all,
I contacted our Viewer Relations team on your behalf who confirmed ch501 should not be PIN-protected, if you have any more examples of this please pop them in here with the time and programme running at that time and I'll have our technical teams look into it.
New reply below
Thanks,
Chloe-W22
Hi all,
Chloe-W22
This message was authored by: MG57
Hi
I've had this problem before and rang Sky - they told me to turn of the sky Q box and it did the trick. Now it's happening again on Sky news 501 - it is happening every time I go back to it. It is frustrating and stopping my enjoyment as I channel hop
Who is "Natahhyu"?
This message was authored by: idle+road
I've had this issue today .
started to work itselfs after an hour .
i only have broadband - had a sky package ages ago so sky staff or the website couldn't  help either !!
