This discussion topic has been answered Discussion topic: Sky Multiscreen
Message posted on ‎09 Nov 2023 10:02 AM
I have power points and the TVs ready to go but do I need any sort of internet connection in the Mini Box rooms or just for the main box downstairs? TIA
Message posted on ‎09 Nov 2023 10:26 AM
Hi @AJ291
You don't need any Ethernet connection sockets for the mini if that's what you mean as mini boxes normally work on WiFi from the main Q box (or the Sky Q router if on Sky Broadband).
The main Q box also uses WiFi connection to the router.
That said if Ethernet if connections are readily available for all Q boxes this is a bonus as full Ethernet connection is ideal.
Message posted on ‎09 Nov 2023 10:08 AM
Re: Sky Multiscreen
@AJ291 wrote:I have power points and the TVs ready to go but do I need any sort of internet connection in the Mini Box rooms or just for the main box downstairs? TIA
It depends (but probably).
The Q will create its own network between boxes - the mini's act as slaves to the main unit.
If you want to run apps on your mini's then they connect to your WiFi directly.
If Sky are installing then they have extenders where needed.
Hi @AJ291
