Discussion topic: 2 sky boxes not working
Message posted on 09 Nov 2023 10:37 AM
My one sky box hasn't been working for some times, the other one is now not working, they are quite old (6 years or so)
Message posted on 09 Nov 2023 10:47 AM
Re: 2 sky boxes not working
Hi @GG109
Reboot the mini as above.
