5
This discussion topic has been answered Discussion topic: Sky Mini boxes No TV Signal
This message was authored by: hibeenicol
Starting last night my Mini box shows no satellite signal.
Tried troubleshooting by doing the normal.
Reset Network
Reactivate connection
Switch off
Switch off/On with reset button held
Reboot router
All of these steps done multiple times on Main box and mini box.
I also have a mini box that hasn't been plugged in for a while and tried that. As soon as it was connected it has the same issue.
Mini boxes show that they are connected to the main box and the network.
Things not working -
Live TV, TV Guide and recordings.
Everything requiring internet works fine.
Anyone else have the same issue, I think the main box is the issue and unfortunately probably needs replaced by an engineer.
Avatar for hibeenicol
This message was authored by: hibeenicol Answer
Re: Sky Mini boxes No TV Signal
Yeah I did that as well.
I've managed to resolve the issue by resetting the hard drive on the main box. Unfortunately losing all recordings but it has resolved the issue for now.
Reset Network
Switch off
Reboot router
@hibeenicol I can see what you have said you have tried but the only thing I don't see is if you have rebooted the main box first then rebooted the mini boxes
ie
putting your main box into Standby then switching it off at the wall for 30 seconds
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Adamduff
I'm having the same problem, checked dish and cables seem ok.
sky q box turned off and on with remote and power has been cycled.
Still no signal.
A visual check of the dish isn't going to confirm whether the dish is slightly out of alignment.
Still no signal.
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
For a “no satellite signal” message look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
This message was authored by: pc0889
Yes. A hard drive reset works. Thank you for great advice.
