Discussion topic: Intermittent loss of sound
Message posted on 18 Oct 2023 07:24 PM
Sound is lost at random times. Change channel then go back and the sound is there again. Happens on both the main Q box and mini boxes - so with different TVs, cabling etc.. Picture remains good.
Message posted on 18 Oct 2023 08:20 PM
Re: Intermittent loss of sound
Hi @Lisvane
Try a Reset Settings in the main Q box hidden menu.
Message posted on 18 Oct 2023 08:40 PM
Thanks for that.
No need for hidden menu- reset available through settings menu.
I've done that so will see if the problem re-occurs!
Message posted on 18 Oct 2023 08:46 PM - last edited: 18 Oct 2023 08:47 PM
Message posted on 26 Oct 2023 07:33 PM
Well it was OK for a few days then the problem started again!
Message posted on 08 Jun 2024 10:12 PM
I had this problem when I switched off WiFi from the router. When I switched it back on, the problem disappeared.
