Discussion topic: Sky Mini Box not working
Message posted on 24 Dec 2024 07:10 PM
Hi
sky mini box not working.
Have rebooted and get the Hello screen then the blue screen that says press home button when screen goes blank.
it then gets no further- mini box light says on orange / red and screen stays black.
Main Sky Box says mini box ok
Suggestions welcomed!
Message posted on 24 Dec 2024 07:12 PM
Re: Sky Mini Box not working
Did you reboot the main box first then the same with the mini box?
Message posted on 24 Dec 2024 08:05 PM - last edited: 24 Dec 2024 08:06 PM
@SeanF2 wrote:
Hi
Hi @SeanF2
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on then with the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 02 Jan 2025 01:51 PM
Solved- thank you all!
