Discussion topic: Sky Mini Box issues again
This message was authored by: TaffAllen
Sky Q Mini box has again disconnected from the main box. 45 minutes rebooting and now stuck on menu screen with Sky Info channel. This happens far too regulary for a box less than 3 metres from main box. Having to use this method to raise the issue is equally frustrating.
Re: Sky Mini Box issues again
Hi @TaffAllen
Reboot the mini as above.
Avatar for TaffAllen
I'm sorry but this response just underlines the frustration I have with Sky. Do you think all this has not been tried. What sort of idiot do you take me for? The reality is that the Sky Q mini boxes are somewhat underwhelming when it comes to software. Unlike the rental costs which, given the regularity of their breakdown, if far from underwhelming.
hi @TaffAllen
If you do not specify what you have tried then I don't know what you expect.
@TaffAllen
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
This message was authored by: Tom-W19
Thanks for escalating. We've sent an invite to @TaffAllen.
Tom
This message was authored by: Greenfingers001
We are still looking to help you @TaffAllen . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
