Discussion topic: Sky MIX and catch up
This message was authored by: Wibbly-Woo
Why is Sky MIX not available on Catch up ?
Re: Sky MIX and catch up
I can only assume because Sky Mix is full of re-runs of content that has been shown previously on the other Sky channels?
They have recently started showing "The Rookie" on Sky Mix for example which on demand would be under Sky Witness as that is where it was originally shown and is up to series 6.
Is there something specific you are looking for?
Avatar for Wibbly-Woo
Level 4 icon
Just Star Trek Voyager - we are watching it yet again and missed the first 4 episodes !
OK.
The on demand rights seem to suggest it is on Paramount+, but that requires a seperate subscription (or comes with Sky Cinema).
If you go to Paramount+ direct though, I believe you can get a 7 day trial which should give you enough time to catch up on 4 episodes.
