Discussion topic: Sky Live not working
This message was authored by: LJ19
Since the winds this weekend i have no satellite reception resulting in NO live tv on any channel!!
Re: Sky Live not working
Follow this to conclusion: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
@LJ19
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
