3
This discussion topic has been answered Discussion topic: How do I get a Sky Q box that supports 4K
This message was authored by: Dawn44
I've just upgraded from Sky+ to SkyQ but have found it doesn't support 4K. Is there  a SkyQ box that does support this? And how do I get one? Thanks
This message was authored by: MightyQuinn Answer
Re: How do I get a Sky Q box that supports 4K
Hi @Dawn44   Subscribing to UHD is a good start, while you are ordering this tell them you need a UHD box.
@Dawn44 have look at the link below and let us know which Sky Q box you have,
If you can't get 4K at all it would likely be the 32Cxx in which case you would need to contact Sky
https://www.sky.com/help/articles/sky-software-updates
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Dawn44
Thank you - I've just done that and you are correct I have 32C00A.  I'll contact Sky.  Thanks
