Discussion topic: Sky Films Pixelating ?
This message was authored by: Chilster
SKY Q box pixelating on the Movie channels only - 1TB box no issues on any other channels .. Ideas/Help please ?
Re: Sky Films Pixelating ?
Hi @Chilster Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot?
This message was authored by: Incanto
My SkyQ has the same problem, all the sky channels from 301 to 311 they go into a scramble mode til around 6pm then they are ok. I have turned system off at the wall for 5 mins still the same once it get through boot up. Any clues
This message was authored by: Kirsty+S27
Posted by a Sky employee
Hi @Incanto
Welcome to the Sky Community Forum!
I apologise you are having issues with those particular channels. Can you advise how long this issue has been going on for and if possible if you have any photos of the pixelating you are seeing?
Thank you
Kirsty
Community Manager
It would also be useful to know if Sky Megahits (303) is affected or just the other movie channels. Megahits is broadcast on a different frequency to the others.
Channel 303 is not pixelated but all the rest are.
Here is a video of the problem
This message was authored by: Dallen9798
@Incanto
Satellite signal issue, if you cant get the chat with them on here give Sky a call for an engineer to be sent out.
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Hi @Incanto
Thank you for sending the video. Can you tell me if satellite signal has a tick on your box please. You can do this by pressing HOME -> settings -> Status -> satellite signal
Thank you.
Kirsty
Community Manager
Yes has tick.
when you go on more info.
satellite signal.   Locked
signal strength.     30
signal quality.        90
LNB type.        Wideband
Yes has tick.
signal strength.     30
signal quality.        90
LNB type.        Wideband
This message was authored by: Godfrey
@Incanto  A signal strength indication of just 30 is likely to be around 52 dBuV which is the absolute minimum signal strength that a Sky Q receiver can accept.
This is indicative of the signal strength that would be expected if the absolute maximum lengths of coaxial cable had been used between your satellite dish Wideband LNB and the Sky Q receiver.
So, if Sky have used their preferred 'thin lossy' CT63 / WF65 coaxial cable (outer diameter 4.8mm), is the length of coaxial cable that has been used around 45 metres long, or if CT100 / WF100 coaxial cable (outer diameter 6.7mm) has been used, is the length of coaxial cable around 75 metres long.
If the length of coaxial cable that has been used is less than these absolute maximum lengths, then an indicated signal strength of just 30, would suggest that your satellite dish is no longer optimally aligned to receive from the Astra 28.2 degrees East satellite cluster.
Godfrey.
