Discussion topic: Viewing Card
Message posted on 06 May 2023 05:57 PM
Viewing Card
I have the following error message "Please ensure the correct viewing card is inserted with the chip facing up". What do I need to do to clear it?
Message posted on 06 May 2023 06:16 PM
Re: Viewing Card
Message posted on 06 May 2023 07:01 PM
Re: Viewing Card
Thanks for the suggestion. Sadly it did not work. I think it is something to do with the box.
Message posted on 06 May 2023 07:03 PM
Re: Viewing Card
Hi @Eddy63
Message posted on 07 May 2023 03:57 PM
Re: Viewing Card
Thanks for the new suggestion but, sadly, that didn't work either. I finally managed to get through to Sky who decided to replace the box after going through the tests you suggested. A good result in the end but I have to set up the box as it would take another two weeks to get an engineer to do it.
Message posted on 07 May 2023 04:04 PM
Re: Viewing Card
@Eddy63 Here is information on how to set up Q devices
https://www.sky.com/help/diagnostics/setting-up-sky-q/what-sky-equipment-do-you-have
