2
This discussion topic has been answered Discussion topic: Sky Atlantic
This message was authored by: CKwickets
Sky Atlantic
I want to download or watch the Gilded Age on Sky Atlantic but it saying I need to upgrade. I have access to Sky Atlantic for other programs?
This message was authored by: nigea99 Answer
Re: Sky Atlantic
hi @CKwickets
Make sure that you are downloading the correct format for your subscription (i.e. do not try to download the UHD version if you only have HD & do not download the HD version if you don't have the HD add on)
Generally best to change your download preference to maximum level you have a sub for
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
Re: Sky Atlantic
hi @CKwickets
Avatar for CKwickets
Level 0 icon
Re: Sky Atlantic
Thank you, it's now working!
Answered - Go to Answer
