Discussion topic: Sky box
This message was authored by: Me92
Message posted on 24 Jun 2025 07:02 PM
Sky box
Sky will not turn on, need to turn off at plug for a reset everytime i want to use it. Its not the remote as that works fine once its restarted and has new batteries. Think the equipment is just old and past it
Message posted on 24 Jun 2025 07:55 PM
Re: Sky box
@Me92 Then you need to ring Sky I'm afraid. This is a customer forum. If it's a Sky+ box you have then it is no longer replaced by Sky and you would need to look at Q, Stream or Glass if you wish to continue viewing Sky.
